2 Pages<12
#21 Posted : Wednesday, May 7, 2014 12:42:16 PM(UTC)
@ Martin
Also noticed that FMLE streams at 1280x854 from 1280x720 source, does this happen automatically with the vMix streamer?
Because it appears to be a custom setting in FMLE.
imagebotique
#22 Posted : Wednesday, May 7, 2014 2:00:00 PM(UTC)
imagebotique
admin wrote:
Thanks,
To work with YouTube Live you will need to tick the first Bit Rate option in the vMix Streaming window
and fill in your bit rate and size instead of the second. If you tick the second, vMix switches to multi-bit-rate mode which YouTube Live does not support.
worked like a charm Martin. Thanks for staying on top of your product. Those of us out there that depend on this for our livelihood truly appreciate the service.
and thanks IceStream. I am going to play around with both methods and see which way I like the best although I tend to stay with simpler is better.
2 Pages<12
