Mathijs
#1 Posted : Tuesday, May 25, 2021 2:54:12 AM(UTC)
Mathijs
I need to trigger a fade after 19 seconds into a video to a virtual input with same footage with multiviewer enabled, set everything as supposed to, but no sigar.
Trigger Function input duration delay value mix
On TransitionIn Fade input 5 1000 19000 1
#2 Posted : Tuesday, May 25, 2021 3:40:48 AM(UTC)
"Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut."
https://www.vmix.com/hel.../index.htm?Triggers.html
https://forums.vmix.com/...ransitionOut-not-working
https://forums.vmix.com/...ce-X-Seconds-After-Start
Mathijs on 5/25/2021(UTC)
Mathijs
#3 Posted : Tuesday, May 25, 2021 6:07:56 AM(UTC)
Mathijs
Thanks doggy, works fine now.
I already had a déjà vu feeling, but my search did not find the results you posted.
Thank you for the quick reply.
