GT
Scrolling credits stop
Joined: 10/1/2019(UTC) Posts: 8  Location: Vermillion Was thanked: 1 time(s) in 1 post(s)
I'm trying to make scrolling credits that go bottom to top, no problem. My issue is how to make it only display the text one time. I want it to stop scrolling after it has gone through the list one time. I'm using a text document for the data source. Trying to create ending credits that will auto transition at the finish of the text document to a copyright input image.
change the ticker type to "Add" Will trigger the scrolling when the text is added or edited and scroll once
That kind of works, but it will then run once in rehearsal, then something needs to be changed before it runs again for the real broadcast. I'd rather not not be needed since students have a hard enough time entering the data the first time.
Originally Posted by: usdharris  students have a hard enough time entering the data the first time.
With all due respect , are you then not supposed to show them easier ways , like using a simple file as datasource for example or give them the challenge to find one ? Finding creative ways to solve limitations
GT
