Hi Everyone,
In the 24 version of vMix you are able to place a border around your PiP's. A very nice feature, but when I've set the values as i like and i go back to the layers / multi layers tab. Suddenly my border has dissappeared. So then i thought to save the layout as a preset, but also then the border is gone...
Does anyone else had the same experience, or am i doing something wrong?
PIP's as in overlays or as a layer in a Multiview
is the border checkmark checked ?
Originally Posted by: doggy  PIP's as in overlays or as a layer in a Multiview
is the border checkmark checked ? Hi Doggy, Thanks for your reply. I'm talking about the Layers/ multi-view. You can see the borders while changing the settings and the border checked, but after pressing layers again on the left side, the borders dissapear. To make it even stranger: I tried it again today and i got the same behaviour but after a couple attemps it works fine now... I'll keep trying to recreate the problem.
