Sonovideo
#1 Posted : Thursday, May 13, 2021 8:43:39 PM(UTC)
Sonovideo
Spain
Good Morning,
With vmix version 21 I used the List as a playlist to make a show of spots with videos and images.
There was no problem, the jpeg automatically gave them a duration of 10 seconds, the png treated them as a frame.
After updating to vmix version 24, it does not reproduce the images in List, it freezes in the first image that comes out and no longer follows the list, in playlist it does, but I am interested in doing it in List.
Anyone know if there is any solution to this problem.
I hope I have explained myself well and you can help me.
Thank you.
#2 Posted : Thursday, May 13, 2021 9:53:23 PM(UTC)
Playlist and Photos(folder) input allows you to specify display times ,List does not
The NextItem shortcut (or function within a script with counter) allows you to advance items in the list
Also note from vMix : https://forums.vmix.com/...-List-problems#post63727
Sonovideo on 5/13/2021(UTC)
Sonovideo
#3 Posted : Thursday, May 13, 2021 10:35:50 PM(UTC)
Sonovideo
Spain
Thank you very much for your answer.
I have been using List (version 21 of vmix) for years as a launcher for videos and images and it was more useful to do it this way than in photos (since I mix videos with photos) and in playlist it is less useful. It would be very good for me to return to the previous implantation.
#4 Posted : Thursday, May 13, 2021 10:59:39 PM(UTC)
As admin mentioned the reason for this (about 2 years, 3 versions ago ) I doubt it will return especially with the other options available for specific usages.
The API XML specifically defines it as a "VideoList" . But again if really needed a script that checks if the current displayed item is an image could trigger a NextItem after a specified Pause()
