Feature Requests
X-Rite color correction support for multicam
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Joined: 10/9/2019(UTC) Posts: 40  Location: Bålsta Thanks: 2 times Was thanked: 5 time(s) in 2 post(s)
First of all i would like to see that you can use external controllers properly for color correction. "just" like a bing/ccu. if using an external controller now. only the last command is used. so if correcting say red leven and then overall gain the red correction is reset. topic https://forums.vmix.com/...ith-external-controllers
Joined: 10/31/2021(UTC) Posts: 23  Was thanked: 1 time(s) in 1 post(s)
+1
Too complex to match colors with different cameras.
A solution like the color checker would be great if implemented in software.
Feature Requests
