Feature Requests
Border with Merge Animation (Input/Layer) (PLEASE FIX THIS)
Joined: 10/14/2020(UTC) Posts: 4  Location: Las Piñas City Thanks: 1 times Was thanked: 3 time(s) in 1 post(s)
I suggest that when Merge Transition is clicked, the Cropped Borders in Layers should animate also (according to its movements from CROPPED to UNCROPPED layer.) because it's not smooth when merging transition is clicked. The Border animation is left-over with the input. its kinda lagging. hahaha I hope you understand my crappy english 😂🤣
 3 users thanked Johncris256 for this useful post.
Joined: 6/18/2020(UTC) Posts: 26   Location: Manila Thanks: 57 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: Johncris256  I suggest that when Merge Transition is clicked, the Cropped Borders in Layers should animate also (according to its movements from CROPPED to UNCROPPED layer.) because it's not smooth when merging transition is clicked. The Border animation is left-over with the input. its kinda lagging. hahaha I hope you understand my crappy english 😂🤣 +1
 1 user thanked Roi for this useful post.
Joined: 4/28/2021(UTC) Posts: 2  Location: Virginia Thanks: 2 times
YES!! This Please! Gets very clunky dialing in the exact zoom and crop values on multiple layers while maintaning the correct border width across varied placement settings between 1-3ups. The built in border implementation is almost there, would be perfect if the border stayed visible while the source input resized during transitions.
This simple feature is maybe the only advantage I've seen that is better implemented in MIMO Live.....
++1
Yes please. Was excited to see the borders feature, but it's pointless if we need to use Merge transitions. Until, back to the old way of using many layers to create fake borders behind layers. Ugh.
+1
It is very important to fix this! Right now we have to choose between borders and merging.
Joined: 1/26/2021(UTC) Posts: 9  Location: Pittsburgh Thanks: 1 times
+100000 this would be so useful and could make my broadcasts so much more fluid!
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Feature Requests
