Revocayne
#1 Posted : Wednesday, May 12, 2021 4:48:07 PM(UTC)
Revocayne
Malaysia
I've created my own virtual set and UVmaps to fit my virtual event stage but however, I've noticed this weird line that keep showing at the frame sometimes on the top, sometimes on the left.
The line will not go away even if I do cropping. I've tried the green screen settings and it's not because of green screen keying either. Anyone has any idea how to solve this? It has bugged me for quite some time but I couldn't see any solution to this. Thank you.
[img=https://flic.kr/p/2kY9gEV]Custom Stage[/img]
#2 Posted : Wednesday, May 12, 2021 5:01:34 PM(UTC)
were you able to pinpoint which layer of the VS it appears with?
Revocayne
#3 Posted : Wednesday, May 12, 2021 5:54:58 PM(UTC)
Revocayne
Malaysia
It's with the camera layer, where the capture card works for this layer.
#4 Posted : Wednesday, May 12, 2021 6:13:21 PM(UTC)
You are not giving much details are you. is that a regular layer or one you put on a UV map or ....
Is it always at some edge of that layer ( maybe zoom the source in a little in that case) ?
but looks like its could be a camera/capture card issue not a VS one
Revocayne
#5 Posted : Wednesday, May 12, 2021 6:17:34 PM(UTC)
Revocayne
Malaysia
Sorry I'm new to this custom virtual set. The layers are on a UVmap that is add into input for config.xml file.
So the camera layer is added directly to the UVmap through input of the virtual set.
I tried cropping the UVmap edges from it's original file already but still it has the same lines so I assumed it's not the UVmap file issue.
Revocayne
#6 Posted : Wednesday, May 12, 2021 6:19:11 PM(UTC)
Revocayne
Malaysia
I've also tried with different capture card but it gives same results.
#7 Posted: : Wednesday, May 12, 2021 6:36:27 PM(UTC)
and what about different camera ?
do you also see that in the camera input or overlaid on a color input?
What if you use a VS that omes with vmIx , the one that has uv maps in it ?
Did you make the VS ?
matkeane
#8 Posted : Thursday, May 13, 2021 6:07:40 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
I sometimes see artefacts along the edge of UV mapped layers in Virtual Sets I've made. Just a guess, but I think it's due to anti-aliasing when the UV maps is resized/transformed. Usually masking the edge by 1px in Photoshop removes the problem.
thanks 1 user thanked matkeane for this useful post.
doggy on 5/13/2021(UTC)
Revocayne
#9 Posted : Friday, May 14, 2021 3:36:06 PM(UTC)
Revocayne
Malaysia
Yes I made the VS, Thanks for the suggestion to use the VS that comes with vMix. When I uses that it doesn't show the line. So I guess the UVmap that I did was faulty. I'll try again and keep you guys posted
Revocayne
#10 Posted : Friday, May 14, 2021 3:37:18 PM(UTC)
Revocayne
Malaysia
How do you mask the edge? Any particular way to do so? or simply erase the edge for 1px?
matkeane
#11 Posted : Friday, May 14, 2021 6:04:12 PM(UTC)
matkeane
Yes, that did the trick for me, and a 1 pixel crop was enough to remove the dodgy edge, but not make a visual difference in the Virtual Set. I think that particular UV map had been transformed in Photoshop and, perhaps due to the scaling algorithm, the edges seem a bit noisier than ones exported from Blender or After Effects.
#12 Posted : Friday, May 14, 2021 6:11:00 PM(UTC)
Nice
Would be interesting to see if the same issue occurred here
Revocayne
#13 Posted : Friday, May 14, 2021 6:38:53 PM(UTC)
Revocayne
Malaysia
I've used this method but it doesn't work for me. But one thing I realized is because I made the UVmap size accordingly to the stage size. When I refer to others, their UVmap is actually in a bigger size. I noticed edges when I tried zooming in and out using Windows Photos App too.
Revocayne
#14 Posted : Friday, May 14, 2021 6:39:55 PM(UTC)
Revocayne
Malaysia
Nice
Thanks for sharing and yes I used this method to create my UVmap. The original from vMix gives me distorted view which is not usable and it's difficult to change.
Revocayne
#15 Posted : Friday, May 14, 2021 7:33:58 PM(UTC)
Revocayne
Malaysia
I've tried by making the uvmap bigger, and then zoom into proper scale with my stage, but still the problem presents. Also tried cropping edges but couldn't solve it.
I copied the other UVmaps from other VS that doesn't show that line and manipulate with it, it works. However, there's some scaling difference which I need to correct it in vMix.
I have not seen lines anymore but this is just a workaround. Would like a proper way to fix it or a way to create a UVmap using Photoshop instead of using GIMP maybe if anyone could guide me with.
Thanks for all your help and much appreciated.
