VideoList input total duration or per item durations
Joined: 6/29/2020(UTC) Posts: 17  Location: Moscow Was thanked: 1 time(s) in 1 post(s)
Greetings!
Is there any programmable way to get total duration of VideoList Input, or durations of all items from this VideoList? In XML there is only a duration of currently selected item from List.
Thanks in advance.
Upd: it’s available in gui, in List editor. But can’t find same in any API.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
You could check the API XML for the list items and total the duration of each video file with a script
Originally Posted by: doggy  You could check the API XML for the list items and total the duration of each video file with a script Thanks for your answer. But i do not see item’s duration in API XML. Where am i wrong?
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Originally Posted by: caspy  Originally Posted by: doggy  You could check the API XML for the list items and total the duration of each video file with a script Thanks for your answer. But i do not see item’s duration in API XML. Where am i wrong? The duration (in milliseconds) of the currently selected item is shown in the List Input. <input key="59b76d0d-442d-4766-ae8c-2bd5a2579576" number="16" type="VideoList" title="List1 - 3 Lord Selkirk.mov" shortTitle="List1" state="Paused" position="0" duration="226688" loop="False" muted="True" volume="40.96" balance="0" solo="False" audiobusses="M" meterF1="0" meterF2="0" gainDb="0" selectedIndex="5">List1 - 3 Lord Selkirk.mov<list><item>E:\FVM 2019\Videos\5 Mont-Joli.mp4</item> <item>E:\FVM 2019\Videos\1 Precieux Sang.mov</item> <item>E:\FVM 2019\Videos\4 Miles MacDonell.mp4</item> <item>E:\FVM 2019\Videos\6 St Paul Collegiate.mov</item> <item selected="true">E:\FVM 2019\Videos\3 Lord Selkirk.mov</item><item>E:\FVM 2019\Videos\best of FVM 2019 - 01.mp4</item>
Thats was in my original post. In XML i see only duration of selected. But in GUI i see all. Is there a way to get all item’s (or total) durations via API?
Thats was in my original post. In XML i see only duration of selected. But in GUI i see all. Is there a way to get all item’s (or total) durations via API? while not obvious there is a shortcut to allow to "scroll" through the list inputs. means you can loop through all the items and read their duration to add to a total NextPicture/PreviousPicture function the wonders of a quick search ;-) https://forums.vmix.com/...deo-list--input#post5286
Originally Posted by: doggy  while not obvious there is a shortcut to allow to "scroll" through the list inputs. means you can loop through all the items and read their duration to add to a total
I understand this way, but in a common case i can not touch list, cause it may be online when i need durations. another way - i can add and remove as a new input each file from list one by one and grab its duration, but is seems to be a strange way, when vMix already knows this information. vMix team, is it possible to add item’s duration to XML?
 1 user thanked caspy for this useful post.
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Please )))) Up this topic
Joined: 8/17/2023(UTC) Posts: 12  Location: Rio de Janeiro
+1
Did anyone find out how to add list remaining time to an input?
