wmsenna
#1 Posted : Saturday, May 8, 2021 11:49:28 AM(UTC)
wmsenna
I have a PTZ NDI camera using "Sony VISCA over IP" in "Input 1".
I want to create a shortcut to call preset number "5" that is saved in the internal storage of the PTZ NDI camera.
How can I do this using the "NDI Command" shortcut?
Using the "Studio Monitor" application, I can call up a preset saved on the camera. How can I do the same using a vMix shortcut?
My camera's name is "CAM-1" and the IP address is "192.168.37.5". Should I use this in consideration when creating the shortcut? I have not found the NDI documentation.
I appreciate the attention.
mavik
#2 Posted : Sunday, May 9, 2021 4:00:43 AM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
Create a virtual shortcut at position 5. then you can deal with it very easy.
wmsenna
#3 Posted : Sunday, May 9, 2021 6:17:00 AM(UTC)
wmsenna
Yes, but I would like to update the presets on my PTZ control, instead of having to update the virtual vMix inputs.
mavik
#4 Posted : Tuesday, May 11, 2021 4:02:04 AM(UTC)
mavik
Whenever you update a preset on your PTZ you can create a new virtual input. Or vise versa. Whatever you like better.
