Good for single 1080p stream?
Joined: 6/6/2020(UTC) Posts: 34  Location: NC Thanks: 11 times
Found a local pc for a good price I believe and trying to figure out if it would work for us. We only use one 1080p PTZ camera and stream on FB live.
Ryzen 5 2600x Gtx 1070 ti Windows 10 32 Gb ddr ram
Rank:: Advanced Member
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
That should be fine for your stated use case. Even though the GPU is a little old, it should be more than adequate for the job at hand.
 1 user thanked kross for this useful post.
Just found this and it's cheaper than the previous mentioned.
GTX 1660 SUPER 16GB RAM RYZEN 5 3600
That second system is better, and it's cheaper, so what's not to like? :)
Joined: 6/18/2020(UTC) Posts: 26   Location: Manila Thanks: 57 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: TechDad  Just found this and it's cheaper than the previous mentioned.
GTX 1660 SUPER 16GB RAM RYZEN 5 3600 This is much better
 1 user thanked Roi for this useful post.
