SRT
Larix Broadcaster now with talkback function.
Joined: 3/17/2017(UTC) Posts: 445  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 57 time(s) in 51 post(s)
 1 user thanked elvis55 for this useful post.
Joined: 7/1/2020(UTC) Posts: 100  Location: Earth Was thanked: 21 time(s) in 19 post(s)
THAT works incredibly well. Big thanks to the SoftVelum crew !!
Hi I can't seem to connect the talkback function. I have the input from my phone to vmix working well, but then when i create a talkback function it says it's offline. Should I be using a seperate port for the talkback? or any settings I need to be aware off? thanks for any advice.
Joined: 5/22/2021(UTC) Posts: 3   Was thanked: 1 time(s) in 1 post(s)
It's two separate streams being used here. The transmission (from phone) is one stream sending out, and the Talkback is another stream being received (audio only). You'll need to have an output & input setup in vMix to have the two streams happening. I've tested it with one port (ie:5001) being setup as listener on vMix for the output (Talkback) to Larix. Then I add an input to vMix on another port (ie:5011) listener to have the phone call into the vMix for receiving.
 1 user thanked rcarcher76 for this useful post.
Joined: 3/29/2020(UTC) Posts: 103  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
No return video is a huge shame!
Anyone tried SRT Mini Server with the Stream to Studio App? It also works on SRT for the incoming stream and sends a WebRTC (I think) stream for the callers return vision. Very little info about it online.
SRT
