lourivalbnneto
#1 Posted : Monday, May 3, 2021 1:00:57 AM(UTC)
lourivalbnneto
Brazil
Hey,
I am a vMix Pro user and I am having problems with NDI. I use two network cards on the same computer due to other data that I traffic and become corrupted when the NDI is on the same network.
The problem is: vMix sends an NDI signal to the two network cards, but I need that signal to travel only to one of them. Is it possible to configure this way?
vMix Version: 24.0.0.58
ThommiTechnik
#2 Posted : Monday, May 3, 2021 2:37:25 AM(UTC)
ThommiTechnik
Switzerland
Was thanked: 8 time(s) in 7 post(s)
Originally Posted by: lourivalbnneto Go to Quoted Post
Hey,
Yes, that's possible. The network-card, where the NDI os located to, make it as a public network. And the network-card, where the output of vMix is located to, of course to a private network. Then exclude in the firewall-settings the NDI from the private-network, so that all the traffics is routed only on the public one.
Cheers, Thomas
thanks 1 user thanked ThommiTechnik for this useful post.
eduardocfs on 5/3/2021(UTC)
lourivalbnneto
#3 Posted : Tuesday, May 4, 2021 12:28:27 AM(UTC)
lourivalbnneto
Brazil
Your information helped me partially. NDI Tools creates new rules in the firewal as many times as necessary to travel over the network. When I consulted the list of rules, there were more than 10 equal rules enabled for private and public networks. Every time I disabled public connections, he (NDI Tools) created them again, enabling traffic. To resolve it I had to create exit rules blocking each NDI Tools software on public connections.
Thank you for your attention.
jvl
#4 Posted : Tuesday, May 4, 2021 4:52:19 AM(UTC)
jvl
maybe this helps:
thanks 1 user thanked jvl for this useful post.
lourivalbnneto on 7/14/2021(UTC)
