Joined: 9/4/2020(UTC) Posts: 22  Was thanked: 1 time(s) in 1 post(s)
Joined: 10/5/2020(UTC) Posts: 1  Location: Roosendaal
+1 This feature would help so mutch!
Joined: 4/17/2020(UTC) Posts: 50  Location: Washington DC Thanks: 6 times Was thanked: 4 time(s) in 2 post(s)
It would also be nice to REMOVE Program and Preview from Multiviewer. I already have that on my main screen, I don't need them taking up inputs on the Multiviewer. Originally Posted by: cgarwood  It would be nice to be able to define more than one Multiview and assign it to an Output. We are currently using Fullscreen 1 with the 8-input Multiview layout, but there are times where it would be nice to keep that multiview, but send a different multiview (for example 4 PTZ cameras) to a separate monitor for our PTZ operator, or to have a 16-input multiview sent to another monitor.
I know this is technically possible by creating an input and using the Multiview capability to add other inputs to it, but that doesn't give you the labels, audio meters, or colors in the label to distinguish if an input is previewed or live.
Joined: 1/25/2018(UTC) Posts: 15   Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
+1 Originally Posted by: LeeL  It would also be nice to REMOVE Program and Preview from Multiviewer. I already have that on my main screen, I don't need them taking up inputs on the Multiviewer.
also +1
Joined: 3/9/2019(UTC) Posts: 24  Location: Victoria, BC Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Joined: 11/24/2020(UTC) Posts: 7  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Joined: 3/3/2019(UTC) Posts: 17  Location: Buenos Aires Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Rank:: Newbie
Joined: 5/16/2021(UTC) Posts: 9  Location: DC Metro Area Was thanked: 2 time(s) in 2 post(s)
+1
I get around the label thing by just making a PNG in photoshop and putting that on a MV layer, but what's really missing is the ability to get a hook on an input's or output's audio meter and use that as an element. I've worked around that by having an input that's a screen capture of vMix and cropping it down to just the audio meter, but that's....really less than an ideal solution.
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 13 time(s) in 8 post(s)
