Joined: 3/27/2021(UTC) Posts: 13  Location: Markdale Thanks: 1 times
If I assign a button in Panel Builder to "AUDIO" and select any input in vMix, when I click on the button, I see related input audio turn on in the audio mixer and the button tally color changes. It stays that way until I click the button again and the audio turns off and the tally goes back to original color. Works perfectly. If I try the same thing with a bus audio, the audio turns on and off but the tally color doesn't latch the same way as on an input. Any idea what's going on?
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Hi KeithB
This is a bug that was created in 4.0.29. It will be fixed in next update.
Please post future "Panel Builder" related discussions in the "vMix Panel Builder for Win/Mac/Tablets " thread. It will help others with similar issues. :)
cheers, Richard
Thanks for the clarification. I did not see a vBuilder thread.
