Does anyone know how you can remove b-frames for Live Streaming via FFMPEG on the UI? Is this possible?
Would be greatly appreciated if someone could clarify this if they know it's possible or not?
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Try a google search....https://www.programmersought.com/article/61393818634/
Executive Summary: B-frames increase compression efficiency, particularly at If B-frames are not optimized, they should disable adaptive B-frame of their live and VOD streams and the efficiency of their encoding. prepaidcardstatus
