Feature Requests
XML API should include more data of each <overlay>
The XML API currently only returns pan X,Y and zoom X,Y for each layer of each input (Virtual Set or input used as 'multi view'. (See attached XML snippet.) It could include way more data such as:
- active (whether the layer is actually activated or deactivated)
- zoomZ
- cropX1
- cropX2
- cropY1
- cropY2
- borderActive
- borderThickness
- borderRadius
- borderColor
Code:<input key="a9967373-edee-4322-9efe-e29885d6bc25" number="4" type="VirtualSet" title="1 virtualstudiosets.com_9B-MID" shortTitle="1 virtualstudiosets.com_9B-MID" state="Paused" position="0" duration="0" loop="False" selectedIndex="2">
<overlay index="0" key="69d87c32-54e0-4450-a356-315932d72efb"/>
<overlay index="1" key="5addb368-dc84-4797-81e3-1791b3b3190c"/>
<overlay index="2" key="c4f3834b-1844-49c8-a190-b3a0bcf0565c"/>
<overlay index="3" key="0adf56e8-b1fa-4e6d-a6f7-9735429cd466">
<position panY="-0.7" zoomY="0.3"/>
</overlay>
<position zoomX="1.5" zoomY="1.5"/>
</input>
Joined: 5/8/2021(UTC) Posts: 11  Location: Burnaby Thanks: 1 times Was thanked: 11 time(s) in 3 post(s)
Working with virtual meeting talent that are too nervous to remember to stay in the center of their screen can be very difficult to PIP. This API functionality would greatly benefit a workflow for this. I would bet many people are in this situation.
+1 This feature would be very very useful for me.
Additional to stigaards example I would like to have the information which input is connected to which layer. I can set this using the "SetLayer" command, but I can not read it from VMix.
Would be very nice if you could add this information to the XML.
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Dragon  Additional to stigaards example I would like to have the information which input is connected to which layer. I can set this using the "SetLayer" command, but I can not read it from VMix.
the <overlay index="X" ......> gives the key of the input in a layer ! So on can read it and get more details from the layered input consequently
Joined: 8/4/2020(UTC) Posts: 16   Location: Mumbai Thanks: 19 times Was thanked: 4 time(s) in 2 post(s)
+1 Plus the ability to Set Crop via Shortcuts/API
Originally Posted by: doggy  the <overlay index="X" ......> gives the key of the input in a layer ! So on can read it and get more details from the layered input consequently
Thank you! I thought I tested that. Now I tested it again and it works sometimes but not everytime. Have a look at my setup:  I have 4 Inputs. - Colour green
- Colour blue
- Multiview1
- Layer left: green
- Layer right: blue
- VirtualSet with many layers:
- Layer 1 (Skyline): green
- layer 3(screen 1): green
- layer 9: blue
This is the XML I receive, I've shortened some part of the input tag, but I think everything important is present: Code:
<inputs>
<input key="d91d9d63-dc10-47ed-a843-2b14db28eacd" number="1" [...]>Colour green</input>
<input key="0d04de60-7cea-48aa-8b17-51540ef549f2" number="2" [...]>Colour blue</input>
<input key="0e3742bb-b818-4c26-9d5d-02d55e8781d9" number="3" [...]selectedIndex="1">
MultiView1
<overlay index="0" key="d91d9d63-dc10-47ed-a843-2b14db28eacd">
<position panX="-0.40625" zoomX="0.724074" zoomY="0.724074" />
</overlay>
<overlay index="1" key="0d04de60-7cea-48aa-8b17-51540ef549f2">
<position panX="0.40625" zoomX="0.724074" zoomY="0.724074" />
</overlay>
<overlay index="2" key="429cb531-867a-4fbf-9852-a9d7ac390f73" />
</input>
<input key="bbb385bb-4bbd-4643-9d5f-33db7ce42a08" number="4" type="VirtualSet" title="1 virtualstudiosets.com_9B_WIDE" [...] selectedIndex="0">
<position panY="0.03375" zoomX="0.65" zoomY="0.65" />
</overlay>
<overlay index="1" key="d84f4686-65cd-4753-98b7-d0e5d7cec51c" />
<overlay index="2" key="e5cd1ad8-79be-45db-98b9-f72af3a7370d">
<position panX="-0.7" zoomX="0.3" zoomY="0.5" />
</overlay>
<overlay index="3" key="aabbf9c4-9e26-445e-959a-ab7dced2040f">
</overlay>
<overlay index="4" key="45858620-332a-4134-8dc1-f33d1c32471a">
<position panX="0.7" zoomX="0.3" zoomY="0.5" />
</overlay>
<overlay index="5" key="fdafa658-f907-4c5f-9aa4-06fb2c24b540">
</overlay>
<overlay index="6" key="79a55452-e327-42ad-8aca-c41663d1ad04">
<position panY="0.09" zoomX="0.28" zoomY="0.28" />
</overlay>
<overlay index="7" key="1785a74e-a867-41fd-9355-c1f897aa9121">
<position panY="-0.375" zoomY="0.5" />
</overlay>
<overlay index="8" key="141d61a1-6fa4-4b7a-91d6-4fef3263fd15">
<position panY="-0.375" zoomX="0.2" zoomY="0.5" />
</overlay>
<overlay index="9" key="8db60d52-df8c-4684-b7fa-84bd09149886">
</overlay>
</input>
</inputs>
So as you can see it's working fine for MultiView 1. Both overlays have their key set to the key of Input number 1 and 2. This is the expected behaviour. But for input number 4 things start to go wrong: Overlay index 0 is connected to Input number 1 (d91d9d63-dc10-47ed-a843-2b14db28eacd), this is correct. But Overlay index 2 is connected to input key e5cd1ad8-79be-45db-98b9-f72af3a7370d. This key does not exist anywhere else in the XML document. Overlay index 2 should be connected to input number 2 (0d04de60-7cea-48aa-8b17-51540ef549f2). Same problem exists with overlay index 8, this should be connected to input number 2. So I would like to change my feature request to a likely bug report. I'm using vMix version 24.0.0.58 in the Pro edition. Should I post the bug report somewhere else or is this fine in this thread? Also it would be nice if someone could confirm my analysis.
believe they refer to their placeholders which are not inputs but IMO thy should reflectwhen an input is assigned . Report it! (Released section , not here)
Feature Requests
