Egriswold
#1 Posted : Wednesday, April 28, 2021 7:13:55 AM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
Is anyone aware of a scripting command that could be set as a shortcut which would allow Font resizing?
Thank you in advance
#2 Posted : Wednesday, April 28, 2021 7:37:56 AM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
Is there a shortcut for it ?
If not than also not in scripting
Unless
One has a title saved as gtxml, open that file , search for the font size , change that and save the file.... and reload the title
Egriswold
#3 Posted : Wednesday, April 28, 2021 8:39:20 AM(UTC)
Egriswold
I was hopeful it would be possible since a title while in vmix can be right clicked > select title editor then select text source and click the minus button as many times as needed then close editor
#4 Posted : Wednesday, April 28, 2021 8:55:17 AM(UTC)
How often is there a need for that ?
Egriswold
#5 Posted : Wednesday, April 28, 2021 9:34:19 AM(UTC)
Egriswold
only need it once during soccer game broadcast, when there is additive time to display they want the clock to shrink slightly then the additive time to fade up. The league wants production to use an Expressions graphics system but this is not in the budget. I've been able to emulate almost all the revels demonstrated in After Effects file provided by league except this one.
I'm considering having two clocks running with smaller font sized hidden then toggle them at appropriate time.
#6 Posted : Wednesday, April 28, 2021 6:18:34 PM(UTC)
Sounds like a plan.
Have you tried with any of the ondatachange animations in a GT Title ?
or revert to classic XAML to trigger animations (code behind)
