Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
Hello, I have been playing around to find a way to get rtmp stream as a source in vMix. One way would be to use a flash input and give an url to a flash player, for example: http://video.tiesraides....e-norecord/995&logo=However, in this case for flash applications there is no sound mixed in vMix (for example the above url should produce both video and audio). Can Martin suggest any way to deal with this problem or perhaps there is a plan to integrate rtmp/rtsp sources in vMix ? Thanks, Dundurs P.S. the 0.75x speed feature of video delay really came in handy :)
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi Dundurs,
I will see if there is a way of including rtmp support in a future release.
Martin vMix
Thanks. But perhaps enabling audio for swf is easier and faster solution? we have a broadcast planned on Tuesday and this feature would make a lot of difference :)
Ok, I have done some longer tests with embedding rtmp stream in vMix using flash application and it seem that this scenario is not stable and actually cannot be used.
I've tried that http url in vmix using the Flash input and the sound works but there is no way to mute the audio or adjust the volume. This is a limitation of Flash itself as it provides no functions to adjust audio at all unless programmed into the swf file.
Martin vMix
Rank: Guest
Groups: Guests
hi martin and dundurs, rtmp support would be realy wonderful, the "icing on the cake". 1 more vote... regards, melody www.espiritosanto.cc
