GT
Animated image in GT
Both images are the same !
one is limited to using pages or image sequences with GT titles for in use/ displayed title animation But if you want to start overlaying the image , do the animation and then overlay out that will be less of a problem
Did you search the forum or watch the video turorials to see what your possible other options are ?
Before writing here I searched a lot on the web, but I didn't find anything. It seems that GT cannot do a true animation of the levels. What I need is to move a level on the x or y axis. :(
Again: both links to the images are the same image , so no idea what animation you are trying to achieve
This is the link where you will be able to see the type of animation I am trying to do. Obviously what you see I can insert it as an image sequence, but if I have to insert some text, how can I animate the text following the image below? https://drive.google.com...jHlvjXl/view?usp=sharing
Originally Posted by: Nik Ieva  This is the link where you will be able to see the type of animation I am trying to do. Obviously what you see I can insert it as an image sequence, but if I have to insert some text, how can I animate the text following the image below? https://drive.google.com...jHlvjXl/view?usp=sharing GT title animation are triggered by a situation like ontransition or datachange Each animation consist of a delay (from the start of the transition) and a duration one can have multiple animations per element or layer , most animations are only visible within the layer ( hint , a layer does not need to be full screen ) Below is done with just that an element is animated and faded out while another on top (same shape) is faded in at the right moment (fade time extremely short) You can do the same with text elements (each text will need to have to textboxes) The rest is all playing with the timing
Great, that's what I was looking for. I read what you wrote several times, and I saw the video, but I didn't understand how you managed to move the texts. You say you use animations, but which ones of what kind? You could take some screenshots for me or, better it would be, a mini tutorial :) I would be very grateful to you.
ps. I don't know english well and I get help from google translator, it may be that some of your sentences are translated badly by google.
This should help somehow , to hard to go into all the steps in writing or video Same principle for the text  substitude.JPG (175kb) downloaded 10 time(s).
GT
