Could there be a copy button to copy the properties of an element (X, Y, Pan positions) in this field then paste into another element's properties.
I understand all this needs to be coded and is easier said than done but would be super handy rather than having to write those numbers down to then retype them all.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
haha thanks. I mean copying all elements on that one page at the same time. To then paste into another element's properties then you can move the one element that may need moving. E.g. moving from left to right.
Originally Posted by: DavoPOW  haha thanks. I mean copying all elements on that one page at the same time. To then paste into another element's properties then you can move the one element that may need moving. E.g. moving from left to right. Sadly the API XML only holds the zoom and pan data as a script could fix copying from one to another for all What sort of works also is making a virtual copy of the input and change its input content (prob quicker to implement)
Thanks doggy. Yeah, virtual input is my go-to method atm too. I dont understand the coding behind it so thanks for clarifying. Bottom line, I love vMix!
