The option to add a thumbnail to an element in the main view would be brilliant rather than having to play a video, pause it to then use it as a thumbnail.
A lot of my videos start with a black screen so frame one as the thumbnail isn't ideal and again, when you have dozens of videos, clicking play, then pausing to get a thumbnail visible that is relevant is a bit laborious.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: DavoPOW  The option to add a thumbnail to an element in the main view would be brilliant rather than having to play a video, pause it to then use it as a thumbnail.
A lot of my videos start with a black screen so frame one as the thumbnail isn't ideal and again, when you have dozens of videos, clicking play, then pausing to get a thumbnail visible that is relevant is a bit laborious. One could trigger them to go to a certain position after a transition out or overlay out or other situations or a hover shortcut to do the same for example
