Feature Requests
Record Button Turns Yellow on Dropped Frames
Joined: 8/15/2013(UTC) Posts: 108   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
Hi Guys,
Had a show where I set the record settings to vMix AVI on record 1 and MP4 for rec 2 the night before the show .
The morning was very hectic and I did not get a chance to check the settings before hitting the record button before the show. Record button was red, stream button is red, I am thinking I am all good!
Half way through the day I saw the dropped frames indicator for recording going through the roof. On further investigation I saw that the recording settings had reverted to WMV to the local folder. We NEVER use WMV recording so I have no idea why it ended up set like this. Basically the recording was dropping every frame attempted to be written and the recorded files had zero file size.
1. Has anyone else had the record settings reset like this? Is there something I may have done wrong?
2. I suggest a feature request that if the recording is dropping frames it should flash yellow similar to the streaming button indicator.
Cheers
Mike
Feature Requests
