Joined: 4/20/2021(UTC) Posts: 2  Location: Indianapolis
I keep getting an error message when I try to add the camera. I have no idea what settings I should be using. Can anyone help or tell me how to find the correct settings? The error is Value does not fall within the expected range.
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
What capture card are you using and what audio device did you select from the dropdown menu when adding the camera into vMix?
(this should normally be either "none" or the audio device that is directly associated with the capture device and/or camera)
vMix Greg
I don't know the term Capture Card. I am using a Panasonic hcv770 camera that is connected via hdmi to a CAMLINK4K, then connected to my laptop with a usb c
