Joined: 4/20/2021(UTC) Posts: 1  Location: Søborg Thanks: 1 times
CPU Intel Core i9 10850K 3.6GHz (5.2GHz Turbo Boost) 10 core Cooling NZXT Kraken X63 Mother ASUS PRIME Z490-P RAM 32GB DDR4 RAM GPU GeForce RTX 3070 - 8GB SSD 2 TB - Intel Solid-State Drive 660p Series NZXT H510 Elite Black - tempered glass - RGB Corsair RM750x 750W 80PLUS Gold
I want to do 4 sources HD, and 2-4 vMix calls. Lower thirds, playback prerecorded content (HD) and make DVE's with participants. Record the output, stream the output, have 2 AUX outputs for Calls and in studio monitoring.
In another setup I want to ISO record 2-3 4K input and the mix, but no Calls, graphics, streaming etc.
Will these specs work?
Joined: 11/2/2020(UTC) Posts: 7  Location: Lier Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I'm pretty sure that will do :-) it's very similar to my setup. I have 4 screens attached to it and that's 'heavenly'. (2 x HD and 2 x 4k)
I would recommend then a 4 x hdmi input card such as : Blackmagic DeckLink Quad HDMI Recorder (check the number of free lanes on the slot on your motherboard!)
good luck
see ya, G
 1 user thanked Gert Roscam for this useful post.
