Can't see buses to set up talkback on a mic channel
Hi there, possibly a newbie question with an obvious answer. I am teaching myself V-Mix and trying to set up an audio bus (on bus G) to use as as off-air 'producer' talkback to a guest. I'm following the training video on Youtube as to how to do it, but when I go to my Mic channel and turn off the 'M' button to remove my producer mic from the Master, there is nothing else next to the 'M' for me to be able to select my bus - no 'A' and 'B' buttons, this means there's nothing there for me to select 'G'. Can anyone advise? I am running the 60 day free trial, so perhaps this isn't a feature in the trial software?
Thank you!
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
The extra busses are not enabled by default. Have you enabled them under Settings -> Audio Outputs ?
Ah, I did enable, but I only enabled bus G (as G was the one being used on the video). I didn't realise that to access G I'd also haver to enable A and B and I now see them. Thank you!
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ LondonDirect
right click the [M][A][B] buttons of the Input to access enabled buses C-G
