I just got a new PC with Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz 3.70 GHz 32GB RAM and the GTX 3090 24GB model and I keep getting GPU overloaded warnings with even a small production. I am not sure why. Has anyone else had these issues, and if so, what have you done to fix them? Thanks in advance!
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Sure you have the very latest driver? Only that one works with VMix.
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Same exact issue here. RTX 3090 and vMix showing GPU overload errors. Previously I had a 1080ti and never saw those errors.
Just for the sake of keeping notes on my end, vmix 23 (performance problem 100% gpu etc..) did not work with my RTX 3090 and i have to use vmix 17 to enjoy normal functionality.
Im noticing that vmix 24 is out and was wondering if the issue was addressed and fixed for anyone? Since i have quite a complicated setup before going all out rebuilding it on vmix 24 i'd like to know if we good now.
thanks!
