Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi all i want to make a virtual set like the pic (its a photo montage)
i want to know more info about coordinate for the XML file. where is x=0 and y=0 on the picture? i dont understand
And how to make the <zoom ... for each picture
thanks for your help David
Design the set with a multilayer , get the coordinates of the individual elements from there and write them into the config file of the virtual set All the assets have to be in the same folder of the virtual set
There are also a few videos on how to create a virtual set if one googles "vmix create virtual set"
Also multiple posts in this forum about virtual sets
thanks yes i do that i export my virtual set. its ok. but to make the diffrent "zoom" line. its for that i wanted to have more explain about the coodinate. thanks Doggy
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
You can actually set zoom/pan/tilt by right clicking on the thumbnails on the right of your virtual set.
Or you can preset those in the Virtual set config file.
 1 user thanked Vince Beck for this useful post.
Probably be simpler/easier using 4 multilayers(views) and merge between them
