one audio source three cameras and one video
You have been a member since:: 4/14/2021(UTC) Posts: 14
i have all the audio coming from one source. 3 cameras and one video source. no audio is coming from any other source. How do i set that up?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
You can bring the audio as its own input, or bring it in with the camera.
If you bring it in with the camera, disable follow audio on that input so that it stays on until you decide to mute it.
thank you. where do i find the don't follow audio?
That’s in the mixer panel on that particular input.
im looking at the audio mixer and i just dont see it / i have basic hd/
ok heres what ive got and am trying to do. i have focusrite saffire interrface in play ing musuc live in. i have 3 cameras thart are record vide . one of the is set to the audio interface the other two the audio uis set to none. so cam one has the audio. im roll a video clip in with a fire place burning, i only want the audio from camera one. i have irt switcvhing every 19 sec with the plauy list looped.
hit record and i get no audio.
Ok, do you see audio on the camera input meter? What color is it?
yes i do . as im trying to record it is there any other setting i need?
Is it blue or green? Are you seeing levels on the master?
blue and the arrows are highlighted
no levels on the master output
Then your audio input is off. Click the audio tab on the input itself.
ok the master nis showing butim nt recording any thing/ and the record window is empty
maybe its a record setting now that everything else set up right
Are you recording in VMix? If record audio settings are set to master (It is by default), than you should be recording anything that goes to master.
its set t o master . the m is highlighted on the channel and the speakers on
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Perhaps it would help if you posted a screen grab of the entire vMix GUI window. That would be a good starting point for people to see some of the settings, etc, without you having to try to describe things which you're evidently not that familiar with.
