hparsons
#1 Posted : Wednesday, April 14, 2021 3:29:54 AM(UTC)
hparsons
I want to program a Stream Deck key to pause the active video (using Companion).
The following command will work for the specific input:
localhost:8088/API/?Function=PlayPause&input=60
The problem is that I don't want it for a specific input, I want it for whatever video is in the active screen. I've tried the following:
localhost:8088/API/?Function=PlayPause&input=active
localhost:8088/API/?Function=PlayPause&value=active
localhost:8088/API/?Function=PlayPause&active
None of those worked. Surely there's a setting that will PlayPause the active video.
hparsons
#2 Posted : Wednesday, April 14, 2021 3:34:06 AM(UTC)
hparsons
OK, I feel embarrassed. I THOUGHT I had searched the forum and didn't find a similar problem. I was using PausePlay instead of PlayPause. After noticing my error when posting my attempts, I search the right term and found it.
localhost:8088/API/?Function=PlayPause&input=-1
Minus One (-1) indicates the active display.
