AlanZ
#1 Posted : Wednesday, April 7, 2021 11:10:17 AM(UTC)
AlanZ
I know that I can use activators (inputAudio) to change the color of a button on a Streamdeck, but I was wondering if there is a way to change an input's title, or color so that the input becomes very visible when the audio is turned on or off.
Any thoughts are appreciated.
AlanZ
#2 Posted : Thursday, April 8, 2021 12:27:18 PM(UTC)
AlanZ
Anyone?
AlanZ
#3 Posted : Tuesday, April 13, 2021 12:12:29 AM(UTC)
AlanZ
So is this not currently possible? If so, I will add a post to the Feature Request forum.
AlanZ
#4 Posted : Wednesday, April 21, 2021 1:57:13 AM(UTC)
AlanZ
One last try before I enter this as a feature request... anyone?
#5 Posted : Wednesday, April 21, 2021 2:34:42 AM(UTC)
Not tested but could turning the audio ON/off not trigger putting a color input as top layer on the input if the Audio button turing green under the input is not clear enough!
AlanZ
#6 Posted : Thursday, April 22, 2021 1:13:36 AM(UTC)
AlanZ
Doggy,
That's the kind of thing I'm trying to do.
The question is what triggers the color change (for example if the user clicks on an input's audio button)?
Activators work fine for connected devices (Stream Deck, etc.) but I don't see a way to change an input's properties (perhaps turning a layer on or off)
Suggestions are appreciated.
#7 Posted : Thursday, April 22, 2021 1:30:25 AM(UTC)
Trigger: say you click to change the audio on/off on the audio buttons (not by shortcut) a script can check if specified inputs are Muted or not by checking the API XML
Same script can add/remove a layer @ said input (say a colored frame, bar or icon) etc
Or maybe change those inputs category ( color ) (Scratch this)
Or have a title displaying all that are on or off ....
AlanZ
#8 Posted : Thursday, April 22, 2021 9:37:16 AM(UTC)
AlanZ
Doggy,
Scripting won’t work for me because I would need this to be used with all editions of vMix. I should have mentioned that earlier.
#9 Posted : Thursday, April 22, 2021 11:15:52 AM(UTC)
Yes it will if you do it with a small external "app" instead of vMix's inside script (same logic) ;-)
No edition restriction there
AlanZ
#10 Posted : Thursday, April 22, 2021 11:45:43 AM(UTC)
AlanZ
That’s an interesting approach.
