Overlay control with scripting
Joined: 3/25/2019(UTC) Posts: 38  Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
I have 3 overlays and I want to create a script that checks when I put overlay 3 on if overlay 2 is on of off. When overlay 2 is off it needs to put overlay 2 also on.
Can someone put me on the right track?
Kind regards
Koen
Kind regards
Koen Let the script check if overlay is on by checking if it's empty or not in the API XML If not empty activate overlay 2 but why a script if activating overlay 3 can trigger putting overlay 2 on regardless of if it is already on or not
Hi doggy, the problem is solved. Using the triggers.
Kind regards Koen
