Joined: 9/4/2011(UTC) Posts: 15  Location: South Africa Was thanked: 2 time(s) in 2 post(s)
Hi Martin
Well done on version 2012v1. The function of being able to "slave" record the capture inputs separately is a real bonus. However I only get green looking video pictures when I rec on the multi corder function. I have tried it on two different machines with different capture devices, with the same result of green looking video. Can you tell me please what I am doing wrong.....
Barend
Rank: Guest
Groups: Guests
hi barend, i had the same problem but now has solved... the output format (rgb32, arbg32, etc...) at Performance settings, must be the same that your cameras (YUY2 in my case) test all output formats, restarting vmix when change, and let us know if recording still green. regards, melody www.espiritosanto.cc
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
Hi Barend,
There is a known issue as Melody describes where the output format under Settings -> Performance needs to match the camera. This will be fixed in a future release.
Martin vMix
