Hardware Compatibility
How to use 2x Akai Professional APC Mini midi controllers
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
Has anyone actually been able to use 2x Akai APC Mini midi controllers in vMix successfully? I have tried with Midi-OX & MIDI Translator Pro. I am not able to successfully use one APC Mini on midi channel 1 & the second APC Mini on midi channel 2. vMix either sends button color output to both or none. Have the same issue with midi output from both. Sometimes vMix goes crazy as if the midi intput is in a loop. I have also tried using both of the mentioned programs to map both APC Mini controllers to 2 seperate virtual midi ports. Same issues. It does seem that vMix gets confused as both midi controllers are named exactly the same. Even though this should not be an issue when disabling midi input from the APC minis and using only the virtual midi ports. Is anyone able to assist? Or maybe someone has a configuration file for either of these programs that will do what I am asking. Thank You in advance. :)
Update: I got it working with help from Bome support forum. Midi Translator works great!
 1 user thanked kevev for this useful post.
Hi Kevev,
Can you please forward the info on how to get two APC Mini's to work with vMix?
Joined: 4/27/2018(UTC) Posts: 33   Location: Brazil Thanks: 417 times Was thanked: 19 time(s) in 8 post(s)
Originally Posted by: kevev  Has anyone actually been able to use 2x Akai APC Mini midi controllers in vMix successfully? I have tried with Midi-OX & MIDI Translator Pro. I am not able to successfully use one APC Mini on midi channel 1 & the second APC Mini on midi channel 2. vMix either sends button color output to both or none. Have the same issue with midi output from both. Sometimes vMix goes crazy as if the midi intput is in a loop. I have also tried using both of the mentioned programs to map both APC Mini controllers to 2 seperate virtual midi ports. Same issues. It does seem that vMix gets confused as both midi controllers are named exactly the same. Even though this should not be an issue when disabling midi input from the APC minis and using only the virtual midi ports. Is anyone able to assist? Or maybe someone has a configuration file for either of these programs that will do what I am asking. Thank You in advance. :)
Update: I got it working with help from Bome support forum. Midi Translator works great! Kevev, could you post a photo using two APC Mini on vMix ?
