You have been a member since:: 4/10/2021(UTC) Posts: 1  Location: Iowa
Howdy!
Built some titles using a data set that I want to run automatically. Trouble is, they just keep on running. And they are running in the preview window, which means when I fade in to the credits they could be in the middle instead of the start. I'd like them to start when I cut to them, and I'd like them to stop when the data set is complete, but they just keep looping. When I turn off the loop feature, they don't run at all.
I'm a newbie, so this may be super simple, but I'm struggling.
Any help is appreciated.
Thanks.
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Do you mean a ticker?
In the case, check the ticker settings and set it to Add.
