Joined: 11/5/2018(UTC) Posts: 15  Location: Bielsko-Biała
Do you have such a problem? With these settings (photo), the overlay turns on. But there is no way to disable the overlay in any way. Only selecting the "automatically play with transition" option allows you to turn off the overlay. This was not the case before. And I would like to enable the overlay without any transition assigned.  overlay.jpg (88kb) downloaded 2 time(s).
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
I just learned something new. I never noticed that option in the upper right.
I just now setup my scoreboard title the same as you, all the check boxes unchecked, and the mouse click set to Overlay2.
It works exactly like I would expect. I click on the scoreboard input, and it shows up in overlay 2. I click it again, and it goes away.
The only way I was able to replicate the problem you were having was if I put the scoreboard into the output (as the main output, not an overlay). Then of course enabling/disabling the overlay will have no apparent effect. But then just clicking a regular camera input and sending it to program causes everything to go back to normal.
So sorry I can't be of any help, other than to say it works for me, and thanks for pointing out that feature that I didn't know existed. :)
-- Kevin
