NDI
Vmix Desktop Capture crash issues
Rank:: Newbie
Joined: 3/21/2021(UTC) Posts: 7  Was thanked: 1 time(s) in 1 post(s)
Vmix Desktop Capture crashes when using an application called "Input Director", which is basically a software KVM solution we are trying to implement on our input computers. Crash is random across the machines, and no specific action seems to make it happen.
Problem is solved by using NDI Tools Screen Capture.
Desktop Capture Error message: System.ArgumentNullException: Value cannot be null. Parameter name: destination at System.Runtime.InteropServices.Marshal.CopyToNative(Object source, Int32 startIndex, IntPtr destination, Int32 length) at vMixDesktopCaptureLibrary.Win32Utils.ClearDest(IntPtr dst, Int32 dstStride, Size sz) at vMixDesktopCaptureLibrary.DesktopCaptureServer._CaptureThread()
Input Director info can be found at: https://www.inputdirector.com
Likely has something to do with the show/hide cursor functions, but no combination of options in Desktop Capture or Input Director could solve it.
NDI
