Joined: 3/27/2021(UTC) Views messages in topic : 13  Location: Markdale Thanks: 1 times
I have setup a shortcut on keyboard "M" to send a producer mic to a call on Aux G and key "N" to return the call audio out to Master. Works perfectly.
I added a second shortcut using "M" to "Solo On" the call audio and "N" to "Solo Off". The solo shortcut works but now the producer mic shortcut has been disabled.
The "Solo" shortcuts are in bold black type and not red. If I uncheck them, the original producer mic shortcut works again.
I have re-watched the tutorial video a few times and can't figure out what I am missing. (he was using an external USB keyboard)
Ideas or suggestions?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Keep in mind that a shortcut can be as a key down (holding the key down) and key press and release (Up). I have a feeling that one is up and one is down in your case.
Originally Posted by: Vince Beck  Keep in mind that a shortcut can be as a key down (holding the key down) and key press and release (Up). I have a feeling that one is up and one is down in your case. I deleted the shortcuts and re created them and now it works! The duplicated keys are in red now. I have no idea why. M does one function and N restores. Tried the one button setup but it did not recognize the laptop key press as press "note on" or release "note off". I'm getting an external USB controller soon and will try it again. As it is, the functions I want are working on the laptop keyboard. Thanks
