Jsonner
#1 Posted : Tuesday, April 22, 2014 8:32:58 PM(UTC)
Jsonner
I'm helping out on a livestream project and this is my first time using vMix software.
We were doing test runs of our stream and we moved over to a new computer (My personal PC).
We encountered an error which says "Flash media Live Encoder could not be found" even though the program was installed, was updated to the latest version and (to our knowledge) setup correctly.
I was wondering if it was because I've installed both programs on a separate partition from my Boot drive (C:), but this kind of seems unlikely to me.
Here is a screencap of the error
I can post my PC specs if that would be helpful.
Thanks in advance.
(Also I was browsing for a while trying to find a similar topic, if I missed one I apologize)
ask
#2 Posted : Tuesday, April 22, 2014 9:05:31 PM(UTC)
ask
The error message tells you everything. You MUST download Adobe FMLE and install it. Restart your computer then restart vMix. Find it here: http://www.adobe.com/au/...flash-media-encoder.html
Jsonner
#3 Posted : Tuesday, April 22, 2014 9:08:39 PM(UTC)
Jsonner
Perhaps I wasn't very clear, I'm sorry.
I installed vMix first and then afterwards installed FMLE, restarted and such. Still the same error message popped up.
#4 Posted : Tuesday, April 22, 2014 10:31:57 PM(UTC)
Make sure FMLE is installed to the default directory during setup.
This should be C:\Program Files (x86)\Adobe\Flash Media Live Encoder 3.2
Jsonner on 4/22/2014(UTC)
Jsonner
#5 Posted : Tuesday, April 22, 2014 10:51:30 PM(UTC)
Jsonner
That fixed the problem, thank you sir!
