Joined: 10/10/2019(UTC) Posts: 51  Location: london Thanks: 5 times
Is it possible to create and name a playlist (which is different than say a clip name. We need to be able to play the new playlist out of B independently of A ?
We are recording multiple vox pops Q&A's on a given topic and then need to edit them IN/OUTS and play out the new playlist to Room B's monitor whilst at the same time recording and editing the next set of Q&A's ready to play out when requested.
At the end of the mornings filming we will be asked to playback the same playlists again.
So the question is, can I edit frame accurately the first set of Q & A's ( whilst listening to the audio via a audio BUS ) and playing out of B a different playlist.
Is there anyway to name a playlist or is this called an Event .. can you have a running duration for the event / playlist ?
I am used to using 3play to do this in the past but hope vmix can be an alternative.
