gre2gor
#1 Posted : Tuesday, March 30, 2021 6:55:44 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
When you set replay speed for one of the events the next replay is not playing at 100% but it stays on previous set speed.
pm
#2 Posted : Wednesday, March 31, 2021 4:08:06 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
According the documentation that's the desired behaviour:
https://www.vmix.com/help24/ReplayEvents.html
In my opinion, this behavior is not ideal. If you want to play multiple events and only one event with a different speed you have always to modify two events. The one with the different speed and the following one to set the speed back. And you can't see at event level, which speed it uses. You always have to check the above events if the speed is changed somewhere. I also see some problems if someone starts reordering the events. Then the speeds get completely mixed up.
It would be better if the event speed would only apply to the respective event. Events with "---" should always play with the overall speed selected.
Best, Patrick
Beam52
#3 Posted : Monday, July 12, 2021 8:01:36 PM(UTC)
Beam52
And there he couldn't choose any speed since the Replay was stuck, we only could scroll around the wheel but don't set the speed. A none motion animation ( I made this because someone in my previous post asked).
mypennmedicine
