Feature Requests
More external SDI Outputs
Joined: 12/26/2020(UTC) Posts: 5  Location: Hamburg Was thanked: 5 time(s) in 1 post(s)
Hi vMix Team,
can we please get more SDI outputs? Two is fine for most cases, but having more would be great.
Normally we have Monitors in the Set, feeded by an MiniM/E. If you have two monitors, your two external outputs are gone. So no talent monitor, no clocks, etc... Ok, there´s an additional Fullscreen Output, but that´s something you normally use in the tech-booth to have an additional multiviewer, etc.
NDI might be a thing for a lot of people, but not for everyone.... SDI is often the way to go. So, having more SDI outputs would be really great and an great advantage.
On one of my recent productions I´ve output one 4K signal which I then splitted into four HD Signals.... uargh.... it worked, but was not the way how it should work out puf the box.... -.-
Thanks!
 5 users thanked TheYouth for this useful post.
+1 ... would like to be able to have SDI output of all four External Outputs (on something like a Decklink Duo 2)
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
+1
would do a +1000 if I could
MediaLooks offer a free NDI2SDI tool that allows you to send NDI outputs out as SDI signals. It's a simple app that you can run multiple instances of, but it can fairly easily enable all 4 SDI outputs on a decklink duo 2 for example.
Joined: 12/9/2020(UTC) Posts: 2  Location:: Milan Thanks: 1 times
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Joined: 10/9/2019(UTC) Posts: 40  Location: Bålsta Thanks: 2 times Was thanked: 5 time(s) in 2 post(s)
+1 why not make more outputs while at it and have them all assignable to whatever you want. ndi/sdi/stream/full screen output/call return and so on.
Joined: 5/17/2020(UTC) Posts: 23  Location: Berlin Thanks: 16 times Was thanked: 6 time(s) in 2 post(s)
Joined: 1/11/2021(UTC) Posts: 2  Location: Alsbach-Hähnlein Thanks: 1 times
+1 More SDI Outputs would be great
Joined: 5/31/2020(UTC) Posts: 19  Location: San Francisco
I'm using Newtek Connect to get External 3 & 4-->NDI-->SDI, but it feels like a band-aid. vMix really needs to allow us to assign all 4 External outputs to physical hardware. We can do it on 1 & 2 so opening it up to 3 & 4 should be trivial.
Feature Requests
