Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Hi all -
Currently using the SD version, since I am using SD analog equipment to shoot/stream.
In my monitors I get a nice crisp picture at 768x480, but the recorded version that vMix saves is very soft and fuzzy. I can't use it for making a DVD.
I have tried saving using the following formats: TS, AVI, and MP4.
I don't expect to get an HD resolution, but a nice SD resolution would be great.
Any suggestions for settings?
Switcher is a brand-new Roland, cables are RG59/60, all on BNC
Thanks in advance
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Could you take a screenshot comparing the picture in vMix and the recording?
Martin vMix
Yes, but the issue is when I use the recorded file to make a DVD for the client. A 14 Gb file @ 25Mb should look good, but it looks fuzzy when we burn it to a DVD.
File looks fine when watched on the computer.
I am using the raw file and no reencoding is happening. Using Premiere Pro to build the DVD.
It sounds like Premiere Pro is doing some re-encoding if the DVD looks different to the recorded file. Not much I can suggest if that is the case other than trying some different encoding settings in premiere.
Martin vMix
Rank: Guest
Groups: Guests
coskel22 wrote: A 14 Gb file @ 25Mb should look good, but it looks fuzzy when we burn it to a DVD.
Check you settings, maybe you need to set higher bitrate or try encore to make your DVDs...I use Edius, and I seldom have problems...and edius is not a real authoring program, it is an editor with a simple DVD authoring feature.
Fixed it! The best settings in vMix for DVD production are MPEG-2, not TS or H.264
Looks great now. and so does my livestream.
Thanks!
