JohnG
#1 Posted : Monday, March 29, 2021 3:41:50 AM(UTC)
JohnG
We use vMix to live stream our church services using about 30 inputs comprising cameras, videos, images and powerpoint slides, and also titles and audio inputs too.
As the service runs some inputs are automatically made live by triggers and others are faded manually. Apart from the cameras, each input is only used once and when it has been used I right click on its title to collapse it to be able to see other inputs.
What I would like to do is to have a trigger to collapse each input on its transition out.
I have spent hours searching the manual and trying various things without success.
How can I do this? Am I looking for a feature that does not exist or am I missing something?
#2 Posted : Monday, March 29, 2021 4:21:48 AM(UTC)
If you didn't find a shortcut for it it's because there isn't one
why not split up your inputs under the color tabs , then you would only see about 5 at a time
There is a shortcut to select the color tabs
