jaceawatson
#1 Posted : Wednesday, March 24, 2021 6:34:24 AM(UTC)
jaceawatson
We are using Vmix and have a decklink 4k sdi render card. We are needing to send out the signal through coaxial to our local cable company. What do I need to use to convert the sdi to get a signal to put on a tv? Coaxial is the only input into the box that sends the signal to the cable company. Any help would be appreciated.
Martin Block
#2 Posted : Wednesday, March 24, 2021 9:46:27 AM(UTC)
Martin Block
Philippines
Just order a converter from Amazon.
Search for: hdmi to coaxial cable adapter for tv
Should be easy to get one...
jaceawatson
#3 Posted : Thursday, March 25, 2021 12:55:13 AM(UTC)
jaceawatson
My capture card only has SDI. Is there something that would covert that directly or do I need to go SDI to HDMI to coaxial?
Babbit
#4 Posted : Friday, March 26, 2021 2:08:34 AM(UTC)
Babbit
Was thanked: 26 time(s) in 20 post(s)
You might be in over your head a bit.
Coaxial is a pretty generic term. SDI and analog video, RF, and even analog audio (I'm looking at you, subwoofer lovers) can use coaxial cable, just to name a few.
You're best off getting in touch with the cable company and asking for exact parameters. A manual for the box you're referencing wouldn't hurt either.
If they're expecting QAM or ATSC, there's parameters you need to know anyway. On top of that, those encoding/modulator boxes are expensive, so you want to get that right the first time.
Similar Topics
vMix Call - vMix External renderer (Feature Requests)
by Norlah Rocco 2/12/2021 10:18:10 PM(UTC)
