vMixSocial: invalid OAuth 2.0 Access Token *SOLVED*
Hi all,
I didn't find a solution searching this forum so I create a new topic.
Since a few days, vMix Social Facebook doesn't work correctly. Before, all the time it works fine.
- I can Login to Facebook - vMis is registered in my facebook profile - All would be great so far
But when I click on "Find Posts", there will be an error message and it won't work.
"invalid OAuth 2.0 Access Token Source: FaceBook.FindPosts"
Does someone has a solution for it?
Many thanks!
Best regards Sengajaa
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
are you using the latest update of vMix, it has some fix for Facebook and vMix social
After Update to newest Version (actual 24.0.0.51) now it works! Thanks a lot!
Regards Sengajaa
