GT
GT wont let me create animations longer than ten seconds
Hi there, i want to create a Animation in the GT Title Designer where a text appears after 15 seconds. But if i type in the number it always jumps back to ten seconds delay. Does someone knows a trick how to let a text appear after ten seconds or more?
Greetings
Max duration of transitions in vMix is 10 sec. Same goes for animations in GT titles. I do not know of any tricks to work around this limitation. I think in XAML you are able to make longer animations, but it takes up more GPU mem and CPU load.
Out of curiousity, why do you want longer animations than 10 sec?
Okay then i will try my best in xml :D In my animation i have three text blocks that i want to show one after the other. So i want that the first text block appears at timecode 0 and dissapears at timecode 5. The second should appear after 6 seconds and dissapear at timecode 11 ect.
And thanks for your quick answer.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
You can extract the documents.xml out of the GTZIP and edit it manually.
Originally Posted by: frkstk  Hi there, i want to create a Animation in the GT Title Designer where a text appears after 15 seconds. But if i type in the number it always jumps back to ten seconds delay. Does someone knows a trick how to let a text appear after ten seconds or more?
Greetings
Link a script to it with a pause and make text visible . can build in all the sequences you want
GT
