Feature Requests
Option for vMix API to return JSON instead of XML
Joined: 5/19/2017(UTC) Posts: 106   Location: The Netherlands Thanks: 16 times Was thanked: 36 time(s) in 24 post(s)
JSON structures are becoming the standard when it comes to API responses. It makes it really easy (without any extra libraries/packages) to make a web app and integrate it with vMix.
Is there a possibility that you give an option to return JSON from the API? It would make things a lot easier :)
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
I did search for it, but I couldn't find the post you've given. Thanks! I plus oned it :)
Feature Requests
