Rinsky
#1 Posted : Monday, April 14, 2014 6:01:38 PM(UTC)
Rinsky
Hello
is it possible in Vmix to stream a rtmp livestream without audio?
If so, how? I can't find the option to turn off the audio, there is only an option to minimize the bitrate to 96 bits.
gazreyn
#2 Posted : Friday, April 18, 2014 9:13:39 AM(UTC)
gazreyn
Was thanked: 9 time(s) in 6 post(s)
In the master sound mixer, you can disable to sound of individual sources:
Rinsky
#3 Posted : Friday, April 18, 2014 4:28:17 PM(UTC)
Rinsky
Thanks for the reply, but I need the sound for the local video/audio output.
I want to stream video without audio.
Maximus
#4 Posted : Saturday, April 19, 2014 1:53:13 PM(UTC)
Maximus
Hi Rinsky,
You didn't say how you were encoding, but if You are using FMLE, there is an option to disable Audio as well as ajust the audio level, so you could just turn it down. If you are using a Hardware Encoder there is also usually an option to not include audio. E.G. teradek has a setting 'Audio Disabled'.
I hope this helps.
Maxi
Rinsky
#5 Posted : Saturday, April 19, 2014 6:06:04 PM(UTC)
Rinsky
I'm using the encoder within Vmix (which is basically FMLE), but I can't fina the function to turn off audio, like in the "real" FMLE.
I don't want to use the external output and stream with the "real" FMLE, because a lot of different people will load the Vmix preset and they should just start the stream, without having to start another programm.
I just don't have enough trust in those people's skills and that's why I want to keep it as simple as possible.
