how to Control vmix Streaming Pc AND Songservice PC with Stream Deck?
Joined: 2/21/2021(UTC) Posts: 15  Location: Tirol Thanks: 1 times
Hi, I wonder how to solve the challenge of controlling 2 Pc's in order to work well? Setup: A) Streaming Pc with Vmix and usb Connection to Behringer x32 b) Songservice PC with ProPresenter 7 and Audio Cable connection to Behringer x32 Situation 1) Intro-Video in Vmix streamed to YouTube AND should be shown to audience Live [we use NDI to connect to PP7; In PP7 we use Video Input to show the Video from Streaming PC) >>> Now we fade/cut in vMix to show the Intro, BUT we also need to click Input in PP7 > called: 1 Vmix -Live Window Challenge: If the person on SongPc misses to click Input vMix - nothing will happen on Audience! How can I solve that? - Meaning that the Streaming PC/Vmix or Elgato Stream Deck... has the "power" to Master that alone??? Vis Versa: If we would have a Video in ProPresenter and want to show it to audience in the church, but also to Stream output to youTube. We start it in PP7 AND we need to cut/fade it in vMix How to automate / master that?  hc_137.jpg (748kb) downloaded 1 time(s).
You have been a member since:: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Hi, I have no expirience with ProPresenter. But does it support midi to control to go to the next slide/text? If it does support midi. This could maybe help you
Originally Posted by: Martinius  Hi, I wonder how to solve the challenge of controlling 2 Pc's in order to work well? Setup: A) Streaming Pc with Vmix and usb Connection to Behringer x32 b) Songservice PC with ProPresenter 7 and Audio Cable connection to Behringer x32 Situation 1) Intro-Video in Vmix streamed to YouTube AND should be shown to audience Live [we use NDI to connect to PP7; In PP7 we use Video Input to show the Video from Streaming PC) >>> Now we fade/cut in vMix to show the Intro, BUT we also need to click Input in PP7 > called: 1 Vmix -Live Window Challenge: If the person on SongPc misses to click Input vMix - nothing will happen on Audience! How can I solve that? - Meaning that the Streaming PC/Vmix or Elgato Stream Deck... has the "power" to Master that alone??? Vis Versa: If we would have a Video in ProPresenter and want to show it to audience in the church, but also to Stream output to youTube. AESsuccess LoginWe start it in PP7 AND we need to cut/fade it in vMix How to automate / master that?  hc_137.jpg (748kb) downloaded 1 time(s). The Elgato Stream Deck is an affordable controller for producing live video content with vMix. You can Firstly, plug in your Elgato Stream Deck and turn on your vMix PC. Then you're good to go and you can start using the Stream Deck to control your production. Streaming Mascot Alliance Member.
Originally Posted by: CatherineSullivan  The Elgato Stream Deck is an affordable controller for producing live video content with vMix. You can Firstly, plug in your Elgato Stream Deck and turn on your vMix PC. Then you're good to go and you can start using the Stream Deck to control your production. Streaming Mascot Alliance Member.
I am sorry for not writing it clearer or more understandable: I already use a Elgato Stream Deck XL, BUT that " only " controlls the Streaming Pc and should soon controll Behringer x32 Sound Mixer, BUT The Song Pc is not controlled by that Deck. That where the challenge starts... ................. The streaming Pc with Vmix needs a manuell manipulation on the SongPC in order to Play - lets say a Video - in Front of the house. AND The SongPC needs the same vice versa Possible to automate that?
Have you looked at the midi solution that I suggested?
Originally Posted by: Pepsi(~)  Have you looked at the midi solution that I suggested? Thank you for your help. I will run tests this week. It sounds as absolutely THE solution!!! I will report back to Forum ASAP
Originally Posted by: Martinius  Originally Posted by: Pepsi(~)  Have you looked at the midi solution that I suggested? Yes, I took some time to work that midi solution out, but I was not successful...
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
It looks like bitfocus companion can intigrat with PP7. You will want to set up static ip adresses on both pcs for it to work propperly. The companion vMix integrasjon is not working so well at the time being, so i would just set up a Generic Http instens to trigger a vMix api command and PP7 instens at the same time. Alterntivly you could use VICREO hotkey with companion to trigger a keybord shortcut on the pc with PP7.
